A number of .strm files with (mms: type links) that works on Windows Media Player or on the old XBMC software on the original Xbox does not work with the nightlies I am running on. Can anybody tell me what the problem is?
Guesses could be made, but you'd have better luck if you posted a debug log where you try to play a stream.
natethomas Wrote:Guesses could be made, but you'd have better luck if you posted a debug log where you try to play a stream.
How do you post a debug log?
You can find instructions in the Wiki located
here.
Here is one example, where the stream works in Dharma 10.1, xbox xbmc, and windows media player but does not work with nightlies. I found a lot of mms: files from various websites on the web that fail to work only on the nightly builds including a NASA and National Geographic stream, which I can't find anymore.
02:18:36 T:3044 M:2026336256 NOTICE: DVDPlayer: Opening: mms://mms.hebtv.com/tv1
02:18:36 T:3044 M:2026328064 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
02:18:36 T:6076 M:2026291200 NOTICE: Creating InputStream
02:18:36 T:6076 M:2026274816 NOTICE: Creating Demuxer
02:19:06 T:6076 M:2032361472 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
02:19:06 T:6076 M:2032353280 NOTICE: CDVDPlayer::OnExit()
02:19:06 T:6076 M:2032349184 NOTICE: CDVDPlayer::OnExit() deleting input stream
02:19:06 T:3044 M:2032398336 ERROR: Playlist Player: skipping unplayable item: 0, path [mms://mms.hebtv.com/tv1]
Please use pastebin.com
People generally don't like seeing the debug log in a post, but a link to the full debug log
