Full Version: recently added
Since this day I can't see my recently added movies and series in the home screen.
In the debug log I see the following line:
16:50:03 T:2966384640 M:647933952  NOTICE: Recently added script is no longer needed and the skins should remove dependencies for it
What's wrong?
Until quite recently skins used an external script to display recently added information. It has since been made a part of xbmc itself so an external script is no longer needed. So I guess the skin you're using needs to be updated to make use of the now native recently added infolabels.
thanks. Is it possible that this happened by trying a nightly build and going back to the stable version (was not happy with then nightly build)?.
I'm asking this because Monday the recently added script worked perfectly.
thanks
sjobbels Wrote:thanks. Is it possible that this happened by trying a nightly build and going back to the stable version (was not happy with then nightly build)?.
thanks
same issue here did you get to start working again?
Nightly builds incorporate the script into it's core and the skins (mainly the svn's) have been adjusted accordingly.
if u are using dharma then use the non svn skin in most cases should see you right. though there are exceptions to this but not many.
Tell us what skin you're using will help.
the script is auto updating, because the addon has been updated in the Dharma tree I believe. I just download the old version and replaced only the script not the version file, so that it will not auto update to version 3, which is basically a file that says the error and the error alone.
PS I was using Aeon MQ 2.81 on XBMC 10.1
Here is the link to the old one
http://code.google.com/p/paperstreet/dow...pe-Archive
