Full Version: 3tb GPT drive not showing up in XBMC live
I just got a new 3tb drive (with a GPT partition table) and when I run XBMC live (on a Zbox), the drive doesn't show up. Is XBMC live compatible with GPT and the new drives? Or could this possibly be a problem with my Zbox needing a bios upgrade?
I found out that the problem was the usb external hard drive case. Any one else having a similar problem, you'll have to get a new one in order to use your disk at 3tb (you should ask the clerk if the case is compatible with 3tb drives). Now the drive shows up in XBMC with no problems.
