Full Version: Scrapper file compatibility???
I had used the older Xbox version for years. I have over 1,000 movies and it took forever to get the IMDB scrapped info all corrected. Is there anyway to transfer that file? Are they compatible at all? I plan to have both multiple AT2's and the iPad/iPhones so don't really want to have to do the corrections multiple times. Is there a way to just get all the scrapped info corrected once then copy it to each device?
I used IMDB just because that is what I used before, but maybe one of the others is more accurate. Any experiences?
Do you know how to export and import your video library in the system settings? I'm 90% sure that the last working versions for xbox (officially or unofficially) will be compatible if you export from the xbox and then import to your atv2. As long as things like the network/file paths haven't changed.
Thanks, will try tonight......
