babanoosh Wrote:fixed. mp3 player is broke I guess? switched to dvd player in advancedsettings.xml. now onward to figuring out why sd xvid load so slowly over network and tend to bog xbmc down whereas 720 h.264 mkvs are far faster. confused on that one, haha!
Yeah thanks babanoosh I guess the daplayer is faulty.
Just create the file advancedsettings.xml in the following folder 'var/mobile/Libarary/Preferences/XBMC/userdata' on your ipad, place the code below in it and you will have music playback.
<advancedsettings>
<audio>
<!-- Amount of headroom XBMC should use above the maximum volume level, in decibels. Defaults to
0, valid values 0, 6, 12. -->
<headroom>0</headroom>
<!-- Default audio player: paplayer or dvdplayer (or mplayer on Xbox) -->
<defaultplayer>dvdplayer</defaultplayer>
<excludefromscan> <!-- Regular expressions that if evaluated to true won't be added to library.
<regexp>[-\._ ](podcast)[-\._ ]</regexp>
</excludefromscan>
<excludefromlisting> <!-- Regular expressions that if evaluated to true won't be displayed in
Files View -->
</excludefromlisting>
<!-- Amount of gain (dB) to be applied to AC3 streams that have been mixed-down to 2 channels.
Default is 12.0. Valid values are: -96.0 to 96.0. -->
<ac3downmixgain>12.0</ac3downmixgain>
<playcountminimumpercent>99</playcountminimumpercent> <!-- Minimum percentage that has to be
played before it is considered for incrementing in the Top 100 database view, or for last.fm
submittal -->
<resample>48000</resample> <!-- Force a specific samplerate to be produced by paplayer to send to
the audio hardware, i.e HDMI Audio is usually only capable of 48000. This doesn't work on XBox-->
<applydrc>true</applydrc> <!-- Whether to use DRC on AC3 and DTS streams -->
<dvdplayerignoredtsinwav>false</dvdplayerignoredtsinwav> <!-- set to true to skip decoding of DTS
in wav files when using dvdplayer (10.10 only) -->
</audio>
</advancedsettings>
