Hi Guys,
I've been reading the forum for a while and I'm just about to order a Revo R3700 from ebuyer:
http://www.ebuyer.com/product/261508
I'm going to use XBMC Live.
Is this box suitable?
Also, which remote should I use? I have a logitech that will ultimately get programmed but initially I guess I need a USD IR receiver.
I've seen this on ebuyer as well, will it work?
http://www.ebuyer.com/product/129363
Thanks for your help,
M
mdt73 Wrote:Also, which remote should I use? I have a logitech that will ultimately get programmed but initially I guess I need a USD IR receiver.
Many remotes work and many don't work out. I went with the HP IR receiver that is well known to work in both windows and linux. See the link in my signature for the appropriate model number. I decided to get the package with included remote just so I would have something working out of the box while I figure the Harmony programming out.
HP IR Receiver HP Media Center Remote Control USB Receiver for Windows Emitter/transmitter/receiver/transceiver USB device
(HP P/N: 5188-1667), IR Remote Control (HP P/N: 5069-8344 ), HP bundle P/N: 5187-4592
$24 eBay
Thanks for the reply. I've ordered the Speedlink anyway, it's ony £15 so if it doesn't work I'll get the HP kit. I guess I can always program my Logitech Harmony as an MCE and use the USB IR that comes with the Speedlink though?
Also is the R3700 OK? Although a bit late to ask as I just pressed "order", delivery on Monday, can't wait.......
mdt73 Wrote:I guess I can always program my Logitech Harmony as an MCE and use the USB IR that comes with the Speedlink though
From what I have read on these IR receivers there are differing types. It will depend on what type it actually is.
mdt73 Wrote:Also is the R3700 OK? Although a bit late to ask as I just pressed "order", delivery on Monday, can't wait.......
I didn't end up going with the smaller form factor build so I simply don't know. Others here will though!
