I've got the slider control working for seeking but can't get it to work for volume control.
Am I correct in assuming the action is volume?
ie <action>volume</action>
that's correct.
here's what i'm using:
<control type="slider" id="888">
<description>Volume Slider</description>
<posx>1065</posx>
<posy>66</posy>
<width>130</width>
<height>15</height>
<visible>Player.Playing</visible>
</control>
in which window/dialog are you trying to add it?
afaik it won't work in any of the modeless dialogs, like DialogVolumeBar.xml
That's what I was trying to use it in and surely that's where it's most likely to go?
I've added a global Volume button that opens DialogVolume when focused/clicked and from there want to add the ability to use a mouse/touch screen to adjust it.
I always find that when you manually open it that dialog auto closes too quick
Well I've got it working using a global include with all literally all the code from DialogVolume.xml - which seems wasteful seeing as it's the volume I'm controlling but there you go.
You can always dump it in a different dialog.
