2012-12-04, 22:13
Looks like its working removed the trailing slash of the handbrake path, i'll post back if/when it finishes but once again cheers mate for the help
(2012-12-04, 22:13)wints Wrote: [ -> ]Looks like its working removed the trailing slash of the handbrake path, i'll post back if/when it finishes but once again cheers mate for the help
(2012-12-10, 21:50)rossl1986 Wrote: [ -> ]Hi,
I wonder if anybody can help. I have followed the instructions, and also tried the updated script, and whenever I try and launch it from XBMC all I get is a "script failed: add-on.py" error on the bottom right. I am currently on beta 3 of Frodo but have also tried the stable release of Eden with no success. The script works if I execute the LaunchAutoRipDVD by itself but never when I do it in XBMC. I cannot find the solution to this problem.
Any help would be appreciated.
(2012-12-03, 06:33)kyrios2021 Wrote: [ -> ]AutoRIPDVD Code : Here
Advanced.bat (needed for advanced mode): Here
Update to my previous code:
- You can now choose advanced mode each time you rip
- You can now choose all the options in the beginning so Advanced mode after inputs is fully automated
-All Variables that were set in the original code should carry over to the Advanced.bat ( at least they do for me in testing)
Example:
LaunchAutoRIPDVD from XBMC
The option to do Advanced mode pops up.
Advanced mode interaction:
Rip to MKV:
Encode With Handbrake:
Choose Image Quality:
Keep Original:
"no picture"
After inputing above options the script will run automatically with the supplied criteria
Work in Progress
Working on an effective way to select a mkv if more than one is present after ripping
-This is really for people who want a specific mkv that's not the (largest mkv)
****** Once again this script was made by SpinalCrack and also Akevit
I have only further modified my version and added some additions.
If you have any questions let me know. Once again yay to spinalcrack!
(2012-12-11, 05:15)rossl1986 Wrote: [ -> ]Found the solution. It was a problem with Windows 8. Windows 8 seems to make everything in the program files folder a read only file by default. On top of this my user did not have permission to write to the AutoRipDVD folder, only read access. By changing these, the script worked first time with advanced launcher. I found this out by looking at the xbmc.log.
Anyways, thanks for the help guys much appreciated.
(2012-12-16, 14:05)wints Wrote: [ -> ]Hi back again lol, i'm trying to rip my Star Trek DS9 dvd collection using kyrios script but once i've finished going through the advanced setup it just gives my a loud beep and does nothing any ideas? cheers
Forgot to say its working great with Blu-Ray ripping
(2012-12-17, 15:54)wints Wrote: [ -> ]Hi kyrios, no i haven't I will try that and let you know, thanks for the support
One more thing if i may but could the option to select whether its a tv show or film you want to rip could be added to your script? thanks
