2011-07-10, 11:32
Hi all,
I have put together an AMD X4 system with a Zotac GT 520 video card, and I want to use HDMI for audio.
I tried installing XBMC Live, and then spent the last ~8 hours trying to get sound over HDMI. The current Live install disk does not have NVidia drivers that will work with the GT 520, so they have to be downloaded and installed manually, which will resolve the video issue (XBMC looks beautiful in HD!) but I have been unable to get any sound over HDMI. I've upgraded Alsa, installed a variety of recommended PPAs, followed most every How-To on HDMI that seemed applicable and nothing has worked. Depending on what I have done, launching a video will either display a "can't initialize audio" error, or not, but regardless there is no sound.
As near as I can tell, this seems to be a driver/software issue resolved in later Ubuntu kernel versions, which leads me to my question:
Should I do a minimal Ubuntu install and then install XBMC? If so, what version of Ubuntu? Searching the forums it seems Natty Narwhal is not ready for primetime... Is there another linux variant that might be more appropriate? Or are there any alternatives to XBMC Live that I should consider? (Other than OpenElec--I would prefer a real minimal linux install that can be added to as needed later.)
Or, if you have successfully setup a GT 520 to work with a linux variant of XBMC and have working HDMI audio, I'd love to hear how you did it.
