2011-07-11, 10:27
Hello everyone,
I have some kind of permission problem probably an easy one, it usually is, but I'm stuck and I need help to figure out where it might be.
The trouble is that when I run xbmc (XBMC PRE-11.0 Compiled: May 30 2011 with PVR from Lars Op den Kamps repository running on Ubuntu 11.04 kernel 2.6.38-8) with my ordinary user the remote won't work. I use the startup command "xbmc --lircdev /var/run/lirc/lircd" to point it to the right lircd. But I get these errors in the xbmc.log:
INFO: LIRC Initialize: using: /var/run/lirc/lircd
DEBUG: LIRC: Failed to initialize Inotify. LIRC device will not be monitored.
DEBUG: Failed to connect to LIRC. Retry in 10s.
INFO: Loading special://xbmc/system/Lircmap.xml
INFO: Loading special://profile/Lircmap.xml
DEBUG: Failed to connect to LIRC. Retry in 20s.
and after a while it gives up.
But if I run "sudo xbmc --lircdev /var/run/lirc/lircd" everything works as expected as seen in the log:
INFO: LIRC Initialize: sucessfully started
The thing is that everything has been running without sudo up until a day ago. The only change I can think of is a couple of apt-upgrade, but neither upgraded xbmc or lirc (just a lot of mythtv packages), but something must have happened of course. Also I have no problem using lirc with other applications such as mythtv without running it as sudo. So there is nothing wrong with lirc. Irw shows the right output etc, etc.
I have tried to chmod /var/run/lirc/lircd to 777 but still the same problem.
Might it have anything to do with Inotify failing?
Thanks for any suggestions.
Regards,
Regards,
