Full Version: Is there a way to have sorting nodes (genre, director) apply to smart lists on MQ2?
Hi all,
Old Xbox XBMC user here, who rediscovered the program a few weeks ago when building a new HTPC using the Aeon MQ2 skin Smile
Got mostly everything i want to use going, but one thing that eludes me is how to apply the sorting nodes (by director, by genre, by year) to a smart playlist.
I made a smart playlist as a main menu item in MQ2. Is there any way to add submenu sorting nodes? I already tried using other smart playlists (those did the sorting, but not the selecting choices i get from the nodes)
Would there be any way to call those nodes, either by script or whatever, to act on a designated smart playlist? The general idea is that i want all the sorting options of Movies/TV shows on smart lists as well?
no answer but i would like to how if this is possible as well. driving me nuts when you are using smart filter you only have couple of choices in terms of sorting.
I have spent hours trying to figure out how to do this.
I have Movies and Stand Up Comedy that I wish to keep seperate so I have to make a smart playlist for movies in order to keep stand up comedy out of it.
However by doing that I loose all the sorting options of genre, director, actor , year e.t.c e.t.c
I wish to have the options I get with the default Aeon Movies category with my smart playlist.
Is there a way to do this? If not is there a way to get the default Aeon movies category to ignore my stand up comedy folder? Or even create a custom category for my stand up comedy so that it does not get bundeled in with the movies?
bump
I'd like to know the answer to this too
