Full Version: [RELEASE] IRTrans Plugin
Hi all,
we have just released a native XBMC plugin for all IRTrans devices.
It will work on Windows and LINUX. There is nothing else needed.
Using LAN/WLAN IRTrans devices multiroom solutions are supported.
It is integrated with the irserver SW.
Configuration can be done through the apps.cfg file.
The default configuration uses the MS Mediacenter remote.
To activate the plugin add the parameter -xbmc to the irserver startup.
The green button will start XBMC.
IRTrans
