2011-07-14, 09:13
hello ,
i use xbmc 10.1 on my macbook pro with snow leopard updated .
my prob is to get xs to my smb share folder (win 7)
if i connect to my smb share folder from finder "connect to"
and then run xbmc then everything is running well and i see all shared folder .
the PROB start when i want to connect to my smb from xbmc
i go to videos / file / add smb source and i go to my smb network name
when i click on it , it give me screen with USERNAME /PASSWORD ,
i fill everything in and click ok ,
and i keep seeing the same screen again and again .
the username/pass that i fill is OK .
what could be the prob ? btw same prob in my ipad 2
maby something i need to change in my linksys router configuration ?
thx in advance its relly importent for me .
i hope to get it solved quickly .
moshelog
moshelog
