2011-07-15, 23:06
2011-07-15, 23:47
Or on second thought, does this actually mean there are no streams available for me to watch?
2011-07-16, 04:16
2011-07-16, 22:42
Thanks for getting back to me.
First off let me clarify the situation:
I live in Ireland(hulu not normally available here without proxy - dont have one enabled)
Equipment and software:
Atv2, 4.2.2 jb using pwnage tool
Using xbmc 10.0-9
hulu addon 2.8.9
Addon works fine until I go to open video
Have updated rtmp / the dylib file
Go to open video,
Says please select quality level
No options in list, I.e. Cannot select any quality as none are available.
Pastebin
http://pastebin.com/E9aTrALG
Using xbmc 10.0-9
hulu addon 2.8.9
Go to open video,
Pastebin
2011-07-16, 23:22
thanks for the logs. You are indeed geo blocked.
I will try to add error handling for geo block.
2011-07-17, 12:07
You'll need a VPN to watch hulu. I'm in Ireland too and hulu is working fine with bluecops great plugin on an ipad2 and VPN.
2011-07-23, 18:55
hey bluecop, im seem to be blocked tooo... any addition so far
2011-12-04, 20:33
I too am having the exact same problem. It plays the ads but during them it pops up 'select quality level' but gives me 0 options to choose.
Any help would be much appreciated!
2012-01-12, 00:37
just bumping this thread. has anybody got a solution, maybe a vpn?
2012-01-23, 11:25
This question is mainly aimed at BluleCop
Is there any way to add a proxy for Hulu in the addon settings?
2012-01-26, 14:06
Hi Bluecop / Anyone else who can help?
Has anyone else found a fix yet for the "Please select quality level" i have changed settings for ads to 0 and also selected my preferred quality in settings but this keeps popping up on xbmc screen after i have selected my show here in the UK?
2012-01-27, 03:30
antonshah Wrote:Hi Bluecop / Anyone else who can help?
Have you enabled the proxy under streaming? You have to search a US based proxy and port by trial and error. Google US proxy, I found mine under Hidemyass VPN, they have a list of free proxies for all countries.
Under streaming, set the quality to "Ask". It will show up a list of possible stream quality for you to choose if your proxy is working.
FYI, there is a separate Hulu support discussion in the Video add on :
http://forum.xbmc.org/showthread.php?tid=121023
2012-01-27, 03:41
setting to Ask isn't needed.
