Full Version: Mounting a SSD in Lian Li PC-C37B case
I have a Corsair SSD that did NOT come with any mounting hardware (screws or 2-1/2 to 3-1/2" mounting adapters) and am trying to install it into a Lian Li PC-37B case. The HHD cage in the case does not accomadate this 2-1/2 SSD - at least with any of the supplied hardware. This is all I need to finish my build.
There are not many computer stores around here, just Beat But, Staples , etc.
Would they have the hardware I need? WHat do I really need?
I thought this combo of Corsair SSD and Lina Li case was common - did I miss this detail when these were recommended together?
yeah well,
not all SSD'S come with a Bracket Adapter...
I bought a Corsair Nova 32GB and i came with one so,
i was happy about it!
SSD's are so small and dont produce alot of heat
so, if u dont feel like buying a Bracket Adapter,
you can buy double-sided Velcro and stick it anywhere u want in the case Smile
That was one of my work arounds - double sided tape. I just might have some Velcro lying around - better suggestion.
For the price of the 64GB Crucial SSD, I just "assumed" it would come with hardware that I needed. Well you know what it means to assume ...........
I should have my sticky solution complete tomorrow, then if all else works, it time to go to school with XBMC!!!!!!
yeah!!!!!!!!!
I just sat mine loose in the 3.5" bay.
eskro Wrote:yeah!!!!!!!!!
It really was - after I saw a you tube video that a guy did that - !!!!!
Big GrinLaughBig Grin
thats why SSD's are awesome!!
Just stick it where there's space Tongue
