2011-09-14, 16:25
so i have pushed a new branch in urlresolver called videoid. i haven't updated the docs yet as i don't know if this is the best way to go yet, please read below to see what is going on. i have only updated the putlocker/sockshare plugin.
it adds some complication to the situation, but it also add some flexibility so i'd like to know what people think and whether i should move to this method instead of the existing way of doing things.
it should solve some problems people have had (such as being able to pass a host and media id instead of a full url for example) and although i haven't yet aded it, this will also mean it is easy to sort the choose_source() stuff as it can now be a list of HostdMediaFile objects instead of the current dictionary.
a new object is introduced called HostedMediaFile which represents a (surprise!) hosted media file, check it out here
you make one by passing either a url or a host and a media id:
or are equivalent.
add_video_item() has been changed slightly to allow you to pass anything you like. play is now a dict. so you can pass url, or host and media_id (or anything else you like - should fix eldorados problem)
rather than calling a function i urlresolver, you now call the resolve method on your HostedMediaFile. so t0mm0 test addon has been modified thus:
so, plugins also become slightly more complicated as you have to implement 2 more methods though they are pretty straightforward.
get_url() turns a host and media_id into a proper url for the hoster. in putlicker it goes like this:
get_host_and_id() does the exact opposite - putlocker implementation follows:
valid_url() also has to be updated to check for either valid url or host:
(must be able to make that neater?)
get_media_url now takes host and media_id arguments instead of url, you can get the url by doing self.get_url(host, media_id)
i hope that all makes sense. please take a look and tell me where i am going wrong, and if you think it is worth making these alterations. it certainly solves a fair few problems but i don't want to end up making everything much more complicated!
t0mm0
f = urlresolver.HostedMediaFile(url='http://www.putlocker.com/file/DFE7599AE064911A')
f = urlresolver.HostedMediaFile(host='putlocker.com', media_id='DFE7599AE064911A')
if play:
url = addon.queries.get('url', None)
host = addon.queries.get('host', None)
media_id = addon.queries.get('media_id', None)
stream_url = urlresolver.HostedMediaFile(url=url, host=host, media_id=media_id).resolve()
addon.resolve_url(stream_url)
def get_url(self, host, media_id):
if not host.startswith('www.'):
host = 'www.' + host
return 'http://%s/file/%s' % (host, media_id)
def get_host_and_id(self, url):
r = re.search('//(.+?)/(?:file|embed)/([0-9A-Z]+)', url)
if r:
return r.groups()
else:
return False
def valid_url(self, hosted_media_file):
return (re.match('http://(www.)?(putlocker|sockshare).com/(file|embed)' +
'/[0-9A-Z]+', hosted_media_file.get_url()) or
hosted_media_file.get_host().find('putlocker.com') > -1 or
hosted_media_file.get_host().find('sockshare.com') > -1)
t0mm0
