Hi all - apologies for the simple question as I'm sure this has come up in the past and I am literally 2 mins new to the world of the XBMC forum.
I'm hoping there is a way to show the fanart of the specific artist that is currently playing in the GUI/Visualization mode (Tab Key) for the Alaska skin.
Any help or guidance is much appreciated! Thanks all!
You should ask in [RELEASE] Alaska Revisited (3.0.2) requires nightly build
because Hitcher never answer here
This is the good question I wonder the same
Not currently but wouldn't it be a bit boring seeing the current artists fanart?
You can always use the music fanart as a screen saver.
Personally I would like to see artists fanarts while music playing
actually i´m looking for that too. It´s booring just to see an empty background, and why the cdart with the time release is gone after a few seconds?
There´s a way to activate fanart?
Please...
Geetung Wrote:Hi all - apologies for the simple question as I'm sure this has come up in the past and I am literally 2 mins new to the world of the XBMC forum.
I've found the answer to your question:
open musicvisualization.xml. In <window id="2006"> (top of xml)
Look for
<visible>IsEmpty(visualisation.name)</visible>
Replace this line by
<visible>!IsEmpty(visualisation.name)|IsEmpty(visualisation.name)</visible>
In that way, you've got artist's fanart with or without visualization mode (direct spectrum, waves, etc.)
w2w
