Full Version: PVR Shortcuts
Pages: 1 2 3 4
lorbi Wrote:which sequenze is needed for EPG Data Now, Next and Timeline?
that's not possible. it'll always take the last guide you selected.
Quote:Another question, when i use the "back-button" in a "ActivateWindowAndFocus", this window interpretes it as "ParentDir". What´s wrong?
that's because of a change in mainline. buttons have been changed there. create a ticket for this if you like
EkASs Wrote:When I call DialogPVRGuideInfo, the windows is empty. Is it possible to add a shortcut to the guide of the current program.
from memory, without checking anything: you need pvrguideosd, not guideinfo
dushmaniac Wrote:from memory, without checking anything: you need pvrguideosd, not guideinfo
pvrguideosd show the window with all the programs of the channel, I have to choose the program to see the detail.
What I need is to see the detail of the current program with one key, the guideinfo window (like now but with the data Smile ).
dushmaniac Wrote:that's because of a change in mainline. buttons have been changed there. create a ticket for this if you like
Interesting...when i press the "menu" button (which switched to the home screen before ppa-pvr-46) i get the "Timers" Window...something is mixed up there completely Eek
Cheers Louis
EkASs Wrote:pvrguideosd show the window with all the programs of the channel, I have to choose the program to see the detail.
that's a new feature request
Is it possible to implement a shortcut that starts live-tv, fullscreen, at the latest channel?
yes. add another feature request ticket for that on github or trac
I wrote a comment earlier in this thread about a "shortcut" to record the currently playing show (the sama as pressing M and select record from the OSD). I did not see any info on this (or if it is already possible).
This would be an easy alternative to teach the kids for timeshift (or at least pause live TV)...
Press the recording button, then recordings and play the currently recording channel. Currently it is a lot of steps - Press the OSD button, then left twice, then select... (I hope you get the idea).
/BableFish
feature request ticket please
Ticket #11905 (new Feature Requests) created.
cheers
bablefish Wrote:Ticket #11905 (new Feature Requests) created.
Hey bablefish,
had a look to xbmc-trac. What about that answer? I think it's still not possible. Or what exactly do we have to do?
http://trac.xbmc.org/ticket/11905
bablefish Wrote:I wrote a comment earlier in this thread about a "shortcut" to record the currently playing show (the sama as pressing M and select record from the OSD). I did not see any info on this (or if it is already possible).
We discussed about this in the vdr-portal. This doesn't work anymore. An issue already exists on github:
https://github.com/opdenkamp/xbmc/issues/213
Greetings Hoppel
Curious. When I press "e" on my keyboard I get the timeline. But when I press the dedicated button on my remote, I get an overview for the next "shows" on the actual channel. where is the problem?
Here the relevant parts of my global remote.xml and my Lircmap.xml:
/usr/share/xbmc/system/keymaps/remote.xml
<guide>XBMC.ActivateWindowAndFocus(MyPVR, 31,0, 10,0)</guide>
/home/xbmc/.xbmc/userdata/Lircmap.xml
<guide>KEY_CAMERA</guide>
Under "xbmc-settings-livetv-epg" I configured "timeline" as default.
EDIT:
In the global remote.xml I found a second <guide> under FullScreenVideo.
<guide>XBMC.ActivateWindow(PVROSDGuide)</guide>
I am always on fullscreenvideo. If I change this to the following, everthing is ok, but I think it's not the right way:
EDIT 2:
Ok, I allocated some obc-universalremote-keys to get this working. So this is solved.
Greetings Hoppel
dushmaniac Wrote:teletext is already mapped to the "v" button.
teletext doesn't work for me. I get the message: "teletext not available". From where xbmc gets this data? I use xvdr (vnsi).
EDIT:
--> this is an issue with odk46: https://github.com/opdenkamp/xbmc/issues/217
What about generel key-mappings? When I watch a record, I can't use the standard keys on my remote, like: "play, pause, stop, rw, ff". I think this keys are interesting for future use (when timeshift works), too.
It's probably a xvdr limit. With tvheadend plugin, all these keys work.
Pages: 1 2 3 4
