Full Version: [LIVE] GT210 vs GT430
Seeing as the price difference between these two cards is down to about $25 bucks, I'm curious if there's a real difference in playback quality between these two cards on a Live install. I'd be using a AMD 250 for the processor, AMD770 motherboard, 1GB of Ram.
The extra $25 is definitely worth it.
GT 430 for better post-processing (scaling, deinterlacing etc.) - if you just watch nice 1080p 23.976fps stuff both will do the job.
Do these GPU's support HD Audio?
David
DavidT99 Wrote:Do these GPU's support HD Audio?
David
Only the GT 430 support all HD Formats
GT210 if you dont need to BitStream HD-Audio & Dont need 3D playback
HD5450 if you need to BitStream HD-Audio & Dont need 3D playback (Windows OS only)
GT430 if you need to BitStream HD-Audio & you need 3D playback
Also note that Bitstreaming HD-Audio under Linux is new and not so stable,,,
I believe there's tweaks to make Linux Bitstream Dolby True-HD but,
no luck for DTS-HD Master...
if im wrong on this, plz correct me Tongue
same for XBMC, current version doesnt support HD-Audio Bitstream!
no matter if its windows or linux...
This is something that should be used under a WIndows OS
and like i said. you'd have to use an external player for it to work
like MEdiaPlayerClassic example,,,,
Default XBMC player wont work,,,
ANd 3D playback, well, you have a 3D HDTV??
I use a FanLess Low Profile GT210
and it makes no noise and eats any 2D 1080P movies i throw at it!
The GT210 works well with 3D Side-By-Side. Why not check out the fanless HDMi 1.4a GT520?
live4ever Wrote:GT 430 for better post-processing (scaling, deinterlacing etc.) - if you just watch nice 1080p 23.976fps stuff both will do the job.
Is there any problem with deinterlacing with the 210 card?
Balinus Wrote:Is there any problem with deinterlacing with the 210 card?
Yes
http://www.anandtech.com/show/2939/2
Under normal circumstances (1080p24) the G210 will suffice, but for 1080i (full spatial-temporal deinterlacing) and 720/1080 @ 50/60p this card will not suffice.
ah well, too bad then! :/
