Full Version: Frame drops and strange refresh rate with HDTV in a dual monitor setup with vdpau
Hello everybody,
I have some troubles with my dual monitor setup und HDTV. I'm using the odk40 build for PVR support. Now some word to effects I'm trying to solve
I get refresh rates of round about 35fps with ARD and ZDF HD channels (both 720p50) in my dual display configuration (many frame drops inclusive). When I only connect one display to the system the refresh rate is 50fps and no frame drops. The Anixe HD channel with 1080i50 (think that's the format) is displayed in dual and single display configuration correct.
What is the reason for the implausible refresh rate of the 720p50 tv channels?
How can I get correct refresh rates in my dual display setup?
I also get tearing effects and didn't finde the solution in the forum. Any hints?
I use the nvidia driver with vdpau with an Geforce 8300 chipset.
Thanks,
xbmcstarter
I dont think that card supports that file@that refresh rate, most newer stuff has problems...
