2011-07-24, 18:24
I have the latest xbmc live installed on my ASrock htpc ion system. I tried to install the latest stable Nvidia 275.21 drivers on this system and now xbmc won't start at all. Below are the steps that I followed for driver update:
Now after reboot, I see the xbmc Media Center loading screen and after this it goes directly to the login prompt. I tried logging in as xbmc user and tried to start xbmc using command "xinit xbmc-standalone" but get following errors:
Below is from Xorg.0.log:
How can I fix this and have xbmc start working again
Appreciate your response.
Quote:1. Close XBMC
2. sudo apt-get update
3. sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6 dkms linux-headers-$(uname -r)
4. wget http://us.download.nvidia.com/XFree86/Li...275.21.run
5. sudo sh ./NVIDIA-Linux-x86-275.21.run
Quote:X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-27-server i686 Ubuntu
Current Operating System: Linux S-V-HTPC 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 19:00:09 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-29-generic root=UUID=f3e82b41-225a-40f0-bcc5-95a2019f10ec ro quiet splash xbmc=autostart,nodiskmount loglevel=0 video=vesafb
Build Date: 08 March 2011 08:22:50AM
xorg-server 2:1.7.6-2ubuntu7.6 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 24 12:08:21 2011
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/usr/lib/X11/xorg.conf.d"
Error: API mismatch: the NVIDIA kernel module has version 195.36.24,
but this NVIDIA driver component has version 275.21. Please make
sure that the kernel module and all NVIDIA driver components
have the same version.
(EE) Jul 24 12:08:21 NVIDIA(0): Failed to initialize the NVIDIA kernel module. Please see the
(EE) Jul 24 12:08:21 NVIDIA(0): system's kernel log for additional error messages and
(EE) Jul 24 12:08:21 NVIDIA(0): consult the NVIDIA README for details.
(EE) NVIDIA(0): *** Aborting ***
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
ddxSigGiveUp: Closing log
giving up.
xinit: No such file or directory (errno 2): unable to connect to X server
xinit: No such process (errno 3): Server error.
(II) Loading extension MIT-SCREEN-SAVER
(EE) Jul 24 12:22:27 NVIDIA(0): Failed to initialize the NVIDIA kernel module. Please see the
(EE) Jul 24 12:22:27 NVIDIA(0): system's kernel log for additional error messages and
(EE) Jul 24 12:22:27 NVIDIA(0): consult the NVIDIA README for details.
