Full Version: [Linux] XBMC hangs/freezes on exit after entering video lib
My installation of xbmc on Ubuntu 11.04 freezez every time I exit after I have entered the video Library.
I don't have to play any video for this to happen just enter the video lib, so i can view my video library.
If I just start xbmc and do not enter the video library, xbmc will exit without any problem.
problem-step-by-step:
1. Start xbmc from ubuntu
2. Enter video/movies library
3. Hit esc (1-2 times) to return to main menu
3. Exit xbmc
3.a Using menu option
3.b Using end-key
(The same result using unstable version of xbmc for ubuntu 11.04)
(Note the problem only happens if i enter my video library, have also tried to re-create my user data, nothing helps)
Result:
xbmc hangs and i can't exit it (even the debug info shown on the screen freezes).
Debug-logs:
Failed: http://pastebin.com/XdSgSmdq
normal/okay-exit:http://pastebin.com/n2J0nMnG
I have tried different skins etc, but nothing helps.
Anyone who has any idea how to solve this?
