Full Version: Get 1 Full HD fanart for each series script (linux)
Hi all.
Wrote a little perl script to get 1 full HD fanart per series.
Script processes each folder in the (current) directory, so drop it in the series root folder.
Just wondering if anyone needs such a thing?
regards
Tony
Hi, please eloborate on what it is doing.
And post the script please.
Thnks!
Hi
Basically, under normal operation the fanart that comes down for your series is the first that a scraper finds, this quite often is sub HD. I wanted HD fanart for all my series. So the script gets a list of the fanart for each series and retrieves only if the fanart is 1920x1080, otherwise it doesn't retrieve (leaving whatever sub hd fanart you already have intact.)
If you have a directory called "SERIES" and under it are "The office (US)", "Smallville", "Haven" etc. Place script in "SERIES". It retrieves the names, or manually enter one. Script needs write access in SERIES directory for two tmp files and obviously the ability to save the fanart.jpg files.
Hope it helps
PS, you need to register for free @ thetvdb.com to get an API key and stick it in the script at the appropriate place (check comments)
#!/usr/bin/perl
# 2011/07/19 Created TAS
use LWP::UserAgent;
sub waitkey
local $k;
chomp ($k = <STDIN>);
$k =~ s/\&//g;
$k =~ s/\[//g;
$k =~ s/\]//g;
$k =~ s/\\//g;
$k =~ s/\;//g;
#$k =~ s/\'//g;
$k =~ s/\`//g;
#$k =~ s/\(//g;
#$k =~ s/\)//g;
$k =~ s/\|//g;
$k =~ s/\>//g;
$k =~ s/\<//g;
$k =~ s/\$//g;
$k =~ s/\=//g;
return $k;
sub fileout
$OUTFILE=">TEMPfile";
open OUT, $OUTFILE or die "cannot open TEMPfile for writing\n";
print OUT "@_\n";
close OUT;
sub fileout2
$OUTFILE2=">TEMP2file";
open OUT2, $OUTFILE2 or die "cannot open TEMP2file for writing\n";
print OUT2 "@_\n";
close OUT2;
sub fileout3
$OUTFILE3=">>Processed";
open OUT3, $OUTFILE3 or die "cannot open Processed for writing\n";
print OUT3 "@_\n";
close OUT3;
sub fanartOUT
$OUTFILE=">$listitem2/fanart.jpg";
print "$OUTFILE\n";
open OUT, $OUTFILE or die "cannot open fanart.jpg for writing\n";
print OUT "@_\n";
close OUT;
print "Saved $listitem2/fanart.jpg\n";
fileout3 ("$listitem2");
sub GetSeriesInfo
$name = shift;
chomp ($name);
my $ua = LWP::UserAgent->new;
$ua->agent("MyApp/0.1 ");
# Create a request
my $req = HTTP::Request->new(POST => 'http://www.thetvdb.com/api/GetSeries.php');
$req->content_type('application/x-www-form-urlencoded');
$req->content("seriesname=$name");
# Pass request to the user agent and get a response back
my $res = $ua->request($req);
# Check the outcome of the response
if ($res->is_success) {
return $res->content;
else {
return $res->status_line, "\n";
sub GetSeriesBanners
$ID = shift;
chomp ($ID);
## Just replace with your API key - register for free @ thetvdb.com to get one
$APIKEY = "EEEEEEEEEEEEEEEEEE";
# Create a request
my $req = HTTP::Request->new(GET => "http://www.thetvdb.com/api/$APIKEY/series/$ID/banners.xml");
else {
sub GetThePicture
$Picture = shift;
chomp ($Picture);
#print "Got HERE - http://www.thetvdb.com/banners$Picture\n";
# Create a request
my $req = HTTP::Request->new(GET => "http://www.thetvdb.com/banners$Picture");
else {
system ("clear");
@list_of_directories = `find . -type d`;
shift(@list_of_directories);
print "Manual(m) or Auto(a) lookup? ";
$feedback = waitkey();
chomp ($feedback);
if ($feedback eq "m")
print "Enter Series Name: ";
$Name_of_Series = waitkey();
chomp ($Name_of_Series);
foreach $listitem (@list_of_directories)
@splititem = ();
@splititem = split ("/",$listitem);
$listitem2 = $splititem[1];
chomp ($listitem2);
if ($Name_of_Series ne "")
$listitem2 = $Name_of_Series;
print "Processing $listitem2\n";
$result = GetSeriesInfo ("$listitem2");
fileout ("$result");
# open the tempfile for reading
$INFILE="<TEMPfile";
open IN, $INFILE or die "cannot open TEMPfile for reading\n";
my @SeriesNames = ();
%IDNAMES = ( );
$count = 0;
foreach $line (<IN>)
if ($line =~ /seriesid/)
$SERIESID = $line;
@SERIESID1 = split(">",$SERIESID);
@SERIESID2 = split("<",$SERIESID1[1]);
$SERIESIDD = $SERIESID2[0];
$count++;
if ($line =~ /SeriesName/)
$SERIESNAME = $line;
@SERIESNAME1 = split(">", $SERIESNAME);
@SERIESNAME2 = split("<", $SERIESNAME1[1]);
$SERIESNAMEE = $SERIESNAME2[0];
$SERIESNAMEE =~ s/&amp;/&/g;
push(@SeriesNames, "$SERIESNAMEE");
$IDNAMES{$SERIESNAMEE} = $SERIESIDD;
$Cnt = 0;
## uncomment if you want a choice
# foreach $item (@SeriesNames)
# print "$Cnt - $item\n";
# $Cnt++;
# print "Please choose your Series: ";
# $answer = waitkey();
$answer = 0; # hard coded first choice, comment this and uncomment above to get a choice
$seriesID = $IDNAMES{@SeriesNames[$answer]};
$result2 = GetSeriesBanners ("$seriesID");
fileout2 ("$result2");
# open the temp2file for reading
$INFILE2="<TEMP2file";
open IN2, $INFILE2 or die "cannot open TEMP2file for reading\n";
$check_for_HD = `grep 1920x1080 TEMP2file`;
chomp ($check_for_HD);
if ($check_for_HD eq "")
print "Series has no HD content\n";
else
my @Lines = <IN2>;
$COUNTER = 1;
foreach $line2 (@lines)
if ($line2 =~ /1920x1080/)
$bannerhd = $lines[$COUNTER+5];
@bannerhd1 = split(">", $bannerhd);
@bannerhd2 = split("<", $bannerhd1[1]);
$bannername = $bannerhd2[0];
@bansplit = split("/", $bannername);
$bannerpath = "/$bansplit[1]/$bansplit[2]/$bansplit[3]";
$result3 = GetThePicture ("$bannerpath");
fanartOUT ("$result3");
goto keep_going;
$COUNTER++;
keep_going:;
goto TheEnd;
TheEnd:;
Thanks! Ill try this tonight!
