2011-07-26, 23:56
2011-07-27, 01:01
aoaaron Wrote:http://cl.ly/3V3Z0r1s0k3b0Z2h082V
I think I've named them correctly so why aren't they showing up?!
What are you asking us? Are you giving us enough information to be able to help you? These answers and more at http://forum.xbmc.org/showthread.php?tid=47124
You don't have to do everything that post says, but at the very least you need to clarify your question and include your XBMC.log file.
2011-07-27, 01:38
Its alright. Thanks and also sorry for the lack of information.
FYI for anyone who wants to know why pirates of the caribbean triology doesn't show up as I named, you have to remove 'pirate of the caribbean' for the movies other than the first one.
Peace.
Peace.
2011-07-27, 04:08
ah, you have movie sets, movies sets have to be done in a specific way, which I dont know off hand.
but its clearly documented here
http://wiki.xbmc.org/index.php?title=Movie_Sets
FYI You dont have to remove anything, I have it named exactly (pirates of the caribbean whatver one named) (though Im in Linux) and the scrape and show up just perfectly.
Movie sets see above.
2011-07-27, 11:34
the thing is... i'd rather them not be in a set.
2011-07-27, 15:26
than name them properly
if you have any doubts what naem either check tmdb.com manually search and copy exactly what that says (presuming thats the scraper your using, if not do same with whatevr scarper it is you use.)
or option B use http://www.therenamer.com for auto renaming or configure it so it is looking for names in places you use.
It works fine here in Linux XBMCLive with current xbmc compiled from git.
