Full Version: XELT - XBMC Executor Library Tool (Windows)
I really like the Executor plugin in the Official repository : link.
With this I never have get out of XBMC. Since I do not have a wireless kb/mouse, and using my Android XBMC remote it is quite hard to add new programs, I decided to make a software to help me add programs to the Executor's library outside of XBMC. I thought I share it with you all.
(About Dialog)
Features:
  • Add new programs to the library
  • Edit existing programs in the library
  • Lets you add Parameters and Icons (like Executor)
  • Backs up previous versions in the same directory
  • Option to fix "space in path" issue (converts the path to DOS 8.3)
  • Standalone executable
ToDo:
  • Restore backups
  • Clean code and rid of inefficiencies
Download:
MediaFire
Screens:
Tested on Windows 7 64 Bit
I will open up the source as soon I clean it and then put it up on some project hosting site. Any recommendation ?
Report any issues here. Thanks.
