i have only just started to use XBMC to play music, have started filling my libary with music but unable to play any files, XBMC just restarts
here is the log
http://pastebin.com/jzBt222G
any ideas??
It can't find libmad.so.0
sudo apt-get update
sudo apt-get install libmad0
cheers, no idea why that was missing, is it not a dependency for xbmc??
MikeBuzz Wrote:cheers, no idea why that was missing, is it not a dependency for xbmc??
yes and no.
libmad0-dev is a required dependecy for building or compiling xbmc.
https://github.com/xbmc/xbmc-packaging/b...n/var_info
that's the list of deps for ppa building Ubuntu distributions. e.g.
https://launchpad.net/~team-xbmc/+archive/unstable
https://github.com/xbmc/xbmc/blob/master/README.linux that's for building in any Linux e.g when user compiles own.
in both you can see clearly libmad0-dev
However if you don't compile you likely don't have libmad0-dev installed and when you install libmad0-dev you need and are required to install libmad0...
if your Linux installation or OS of choice doesn't have a Mpeg Audio Decoding (MAD) installed then, you prolly have to install it.
better dependency forcing when you install xbmc can be added but I don't know much about that.
If you install xbmc it automatically
should install all it requires no matter your choice of OS. But clearly its not the case.
that's how I understand it.
