Add-on Support
> Hulu Plugin?
Full Version:
Hulu Plugin?
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Googler
2011-07-29, 10:54
Thanks a lot!
mrdally204
2011-07-29, 10:56
yes, it is. Search for the post on it
Googler
2011-07-29, 11:11
But here it says:
http://gitorious.org/xbmc-hulu/xbmc-hulu...am_hulu.py
The last update date is "Tuesday June 29 2010"?
It should be updated in 2011 to make it work again.
newatv2user
2011-07-29, 17:40
It works. Just use BlueCop's repo to install it. It was recently updated. You might need to manually replace your librtmp though.
mrdally204
2011-07-29, 18:14
This is the relevant thread
Ned Scott
2011-07-30, 00:54
The working Hulu add-on comes from BlueCop.
http://code.google.com/p/bluecop-xbmc-repo/
The one on gitorious looks abandoned.
Add-on Support
> Hulu Plugin?
