Full Version: $INFO[ListItem.Property(Album_Description)]
Is not showing up in DialogSongInfo.xml. It appears if I click on a song and bring up SongInfo afterwards.
Can something be done, please?
Could You provide more details? When exactly it doesn't show because I can't reproduce it.
Those sort of info labels only work in the music library and info windows spiff didn't add them for any others because the song Info dialog is for song info not album or artist info
I think that's why there is a built in control to switch to album info.
pieh Wrote:Could You provide more details? When exactly it doesn't show because I can't reproduce it.
No problem.
In order to reproduce, please, try to put this code
<control type="textbox" description="Plot">
                    <posx>0</posx>
                    <posy>270</posy>
                    <width>700</width>
                    <height>168</height>
                    <font>font13</font>
                    <align>justify</align>
                    <autoscroll delay="6500" time="4000" repeat="10000">Skin.HasSetting(AutoScroll)</autoscroll>
                    <label>$INFO[ListItem.Property(Album_Description)]</label>
                </control>
into DialogSongInfo.xml . Album description will be shown only if you start playing a song and press "I" afterwards. If it would be possible to fix/make it work I could have consistent look of info dialogs.
Another thing, maybe related - I am able to use Artist fanart as a background in DialogSongInfo.xml but not in DialogAlbumInfo.xml
pecinko Wrote:Another thing, maybe related - I am able to use Artist fanart as a background in DialogSongInfo.xml but not in DialogAlbumInfo.xml
This is already possible. I've committed a _fix_ for this today. The other one is a bit more tricky as it might slow down things if it's not only the song dialog that's using the information.
vdrfan Wrote:This is already possible. I've committed a _fix_ for this today. The other one is a bit more tricky as it might slow down things if it's not only the song dialog that's using the information.
Thanks a lot.
As for ListItemProperty(Album_Description) - it appears to be working now in both pre-Eden and Dharma. I am very sorry if it was false alarm - it might have been due to the fact that as I was refactoring info dialogs heavily today and pressed SkinReload a few thousand times during that.
So, it seams to be working. I apologize once again, I should probably sleep more and code less..
No problem Wink
