I have a Hauppauge HVR-4000, it's a hybrid card with DVB-T and DVB-S/S2. Unfortunately Tvheadend only support a single frontend, somebody can apply patch #164 from
http://www.lonelycoder.com/redmine/issues/164 in development source to test it?
Does it?
I'm running one backend and two frontends no problem...easy as.
Just your card?
Well, I have the same issue as the screen.png of the above link, it could be the same card.
did u create the symlinks?
i must have created mine years ago when i built my mythbox because mine are listed as frontend0 and frontend1.
ask andoma (tvheadend developer) to apply that patch directly. it'll be included in the xbmc pvr ppa build too then.
he didn't apply the patch for about a year, so he probably got a reason for it.
xbmcn00b Wrote:did u create the symlinks?
When I create the symlinks, they seem to disappear at every boot, so I don't know if they work.
(Sorry for my bad english, i'm from Spain)
buginside Wrote:When I create the symlinks, they seem to disappear at every boot, so I don't know if they work.
you need udev rules for that.
look here:
http://www.linuxtv.org/wiki/index.php/My..._Frontends
Google is your friend, if you need help with creating udev rules.
