(2013-02-02, 20:09)Skank Wrote: [ -> ]Shall i start a new topic?
I think Roman or panni should start a new topic, because they can always link to the newest build.
(2013-02-02, 20:13)DerKiLLa Wrote: [ -> ] (2013-02-02, 20:09)Skank Wrote: [ -> ]Shall i start a new topic?
I agree but i get the feeling they are not keen on starting one
Maybe he can answer with his next post
I have looked around and need an example of an xml file to use FFDshow Audio with DSPlayer. Can anyone provide me with one?
i just updated to 12.3 and SVP isnt working with DSPlayer, can someone post their config files so i can try them to see what the issue is? thanks!
Hi guys,
Does this integrate wiziwig streams directly into xbmc or am I completely missing the point?
(2014-01-04, 21:49)Makaveli6103 Wrote: [ -> ]I have looked around and need an example of an xml file to use FFDshow Audio with DSPlayer. Can anyone provide me with one?
Look at my post
here for my mediaconfig.xml file which uses LAV Audio decoder.... As long as you have FFDShow filters installed just replace <audio filter="lavaudiodec" /> with <audio filter="ffdaudiodec" />
how can change the Audio output? DSPlayer plays the Sound from my Headphones but I want all XBMC Sounds the be played by the TV and everything else from my Headphones.
Good day.
How can I set DSPlayer up to switch audio streams? Are there any codecs or filters needed?
(If video file contains 2 audio streams DSplayer plays them simultaneously)
I installed DSPlayer 17.3 Krypton - build (20170525-71390e4) on my pc with window 10, but the director's dvd files do not start with DSPlayer, but only with the internal kodi playr.
How do i play dvd with kodi + DSPlayer?
ohcd,
You have posted in the wrong thread. This is the thread you need....
https://forum.kodi.tv/showthread.php?tid=223175
Can you please re-post in the above thread. Once you have done that I will remove these two posts and send this thread back to where it belongs.
