I'll get a new build up in 2-3h when I get home.
vicmanpergar Wrote:@joeydrunk
U said u added lav filters in ur mediasconfig, but i noticed they don't appear anywhere in ur error log, this is something i copied when u're trying to play a MKV:
16:53:10 T:3224 ERROR: Playlist Player: skipping unplayable item: 0, path [H:\Folder Movies-H\Drag Me To Hell.1080.mkv\DRAG_ME_TO_HELL.Title1053.mkv]
16:53:10 T:3224 NOTICE: CDSGraph::UnloadGraph Successfully removed "MPC Video Decoder" from the graph
16:53:10 T:3224 NOTICE: CDSGraph::UnloadGraph Successfully removed "MKV Source" from the graph
16:53:10 T:3224 NOTICE: CDSGraph::UnloadGraph Successfully removed "Xbmc EVR" from the graph
16:53:10 T:3224 NOTICE: CDSGraph::UnloadGraph Successfully removed "Default DirectSound Device" from the graph
And it appears several times in the log, no traces of lav filters. It seems it's using the Mkv source and the MPC filter, not the lav filters. Either u didn't put the mediasconfig in the correct place and it's not loading it, or u have some kind of error there. Check it out.
Edit: this is something i noticed not being an expert in this, with a quick look... May be others can tell u more accurate things
Yep Joey, you've got some wierd shit going on there. Time to recheck the locations of all your files and their set-ups.
Probably a silly question - but you do have LAV Filters installed on your machine?
Yeah I noticed that too but was hoping something in there told why it wasnt reading the lavfilter xml files. Il look it over again. Thanks for the feedback I apreciate it.
steelman1991 Wrote:Yep Joey, you've got some wierd shit going on there. Time to recheck the locations of all your files and their set-ups.
Hahahaha, no its not really that silly of a question, but yes I do have all the current versions of lav Filters and cuvid.
joeydrunk Wrote:Hahahaha, no its not really that silly of a question, but yes I do have all the current versions of lav Filters and cuvid.
Good. That's one thing we can rule out of the equation.
Yeah many thanks Tiben & Owing.... DSPlayer goes from Strength to Strength
>>X<<' Wrote:Its normal pull up "Render Stats" in DSPlayer instead of using "O" its under OSD > Video this will give you exactly the same as showing render stats in MPC-HC they should be pretty much identical when using the same filters in both
Checked! Worked! The fps shown in the render stats screen stays constantly at 23.976 whereas the "o"-screen stays not stable. Thanks a lot.
wooohoo....
Thanks to 0wing and Tiben!!!
So anyone still have problem with subtitle in the new build
tiben20 Wrote:So anyone still have problem with subtitle in the new build
Good morning to all of you
Whenever i change into Owing new builds,trying to change the Subtitles to the Greek ones,or the SRT's,in the Audio Settings,the movie stucks and i have to restart it. WHY?
Also trying through the MPC Splitter in the Video Setting there is not any option for subtitles
Thanks all for your attention and support
Recently, this summer apparently, libass of xbmc have been updated, now in the standard player, all ass feature are supported, and all the test files i have with some tricky feature or specific cases are played perfectly. When i've tried a dsplayer version, all the test files i have failled somewhere to render properly (i'm not talking about a crash issue).
So question about subtitles :
- Is the rendering engine still the same, or has it been updated ?
- If not updated, do you intend, "one day", to update it ?
