alexrose1uk Wrote:Here's the beginners guide for easy setup of DSPlayer (with an eye to Hi10p playback), 0Wing. I've corrected that link typo before shifting it over here.
For any other new users coming into the thread, feel free to use this to help you get up and running quickly.
Thanks a ton for this amazing post; just got Hi10P playback working great on my AMD APU based box. Just one quick followup; DSplayer + LAV Filters seem to handle everything I throw at it with the following exception:
[Ureshii_Saizen]_Real_Drive_-_01_[AAC-H264-720p][D1E7F5F9].mkv
I see the following relevant output in the debug log file:
23:44:34 T:1916 DEBUG: CGUIWindowVideoBase::OnPlayMedia D:\Movies\Anime\RD Sennou Chosashitsu\[Ureshii_Saizen]_Real_Drive_-_01_[AAC-H264-720p][D1E7F5F9].mkv
23:44:34 T:1116 DEBUG: Thread CDSPlayer start, auto delete: 0
23:44:34 T:1116 NOTICE: Loading filter core factory settings from special://masterprofile/dsplayer/filtersconfig.xml (filters configuration).
23:44:34 T:1116 NOTICE: special://masterprofile/dsplayer/filtersconfig.xml does not exist. Skipping.
23:44:34 T:1116 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/filtersconfig.xml (filters configuration).
23:44:34 T:1116 NOTICE: Loading filter core factory settings from special://masterprofile/dsplayer/mediasconfig.xml (medias configuration).
23:44:34 T:1116 NOTICE: special://masterprofile/dsplayer/mediasconfig.xml does not exist. Skipping.
23:44:34 T:1116 NOTICE: Loading filter core factory settings from special://xbmc/system/players/dsplayer/mediasconfig.xml (medias configuration).
23:44:34 T:1116 NOTICE: Successfully loaded rules
23:44:34 T:1116 DEBUG: CDSGraph::SetFile Successfully added XBMC to the Running Object Table
23:44:34 T:1116 DEBUG: Found audio renderer device "AMD HDMI Output (AMD High Defin" (guid: {E30629D1-27E5-11CE-875D-00608CB78066})
23:44:34 T:1116 DEBUG: Found audio renderer device "Default DirectSound Device" (guid: {79376820-07D0-11CF-A24D-0020AFD79767})
23:44:34 T:1116 DEBUG: Found audio renderer device "Default WaveOut Device" (guid: {E30629D1-27E5-11CE-875D-00608CB78066})
23:44:34 T:1116 DEBUG: Found audio renderer device "DirectSound: AMD HDMI Output (AMD High Definition Audio Device)" (guid: {79376820-07D0-11CF-A24D-0020AFD79767})
23:44:34 T:1116 DEBUG: Found audio renderer device "DirectSound: Realtek Digital Output (Realtek High Definition Audio)" (guid: {79376820-07D0-11CF-A24D-0020AFD79767})
23:44:34 T:1116 DEBUG: Found audio renderer device "DirectSound: Speakers (Realtek High Definition Audio)" (guid: {79376820-07D0-11CF-A24D-0020AFD79767})
23:44:34 T:1116 DEBUG: Found audio renderer device "Realtek Digital Output (Realtek" (guid: {E30629D1-27E5-11CE-875D-00608CB78066})
23:44:34 T:1116 DEBUG: Found audio renderer device "Speakers (Realtek High Definiti" (guid: {E30629D1-27E5-11CE-875D-00608CB78066})
23:44:34 T:1116 INFO: CFGLoader::InsertAudioRenderer Loaded audio renderer list. Elapsed time: 13.94ms
23:44:34 T:1116 INFO: CFGLoader::InsertAudioRenderer Loaded audio renderer from registry. Elapsed time: 0.42ms
23:44:34 T:1116 INFO: CFGLoader::InsertAudioRenderer Added audio renderer to the graph. Elapsed time: 0.01ms
23:44:34 T:1116 NOTICE: CFGLoader::InsertAudioRenderer Successfully added "Default DirectSound Device" to the graph
23:44:34 T:1116 INFO: CFGLoader::LoadFilterRules Loading audio renderer. Elapsed time: 14.50ms
23:44:34 T:1916 DEBUG: ------ Window Init (DialogBusy.xml) ------
23:44:35 T:1116 DEBUG: CFGFilterVideoRenderer::Create Allocator presenter successfully created
23:44:35 T:1116 DEBUG: CFGLoader::InsertVideoRenderer Allocator presenter successfully added to the graph (Renderer: Enhanced Video Renderer)
23:44:35 T:1116 INFO: CFGLoader::LoadFilterRules Loading video renderer. Elapsed time: 198.69ms
23:44:35 T:1116 DEBUG: CFGLoader::LoadFilterRules - trying to extract filestream details from video file D:\Movies\Anime\RD Sennou Chosashitsu\[Ureshii_Saizen]_Real_Drive_-_01_[AAC-H264-720p][D1E7F5F9].mkv
23:44:35 T:1116 DEBUG: CFilterSelectionRule::GetFilters: adding filter: lavsource for rule: un-named
23:44:35 T:1116 DEBUG: CFGFilterFile::Create Successfully loaded external filter (clsid:{B98D13E7-55DB-4385-A33D-09FD1BA26338} path:C:\Program Files (x86)\LAV Filters\x86\LAVSplitter.ax)
23:44:35 T:1116 NOTICE: CFGLoader::InsertFilter Successfully added "LAV Source" to the graph
23:44:35 T:1116 ERROR: CFGLoader::InsertSourceFilter Failed to load file in the splitter/source
23:44:35 T:1116 ERROR: CFGLoader::LoadFilterRules Failed to insert the source filter
23:44:35 T:1116 ERROR: CFGManager::RenderFileXbmc Failed to load filters rules
23:44:35 T:1116 INFO: CDSGraph::SetFile Rendering file. Elapsed time: 490.92ms
23:44:35 T:1116 INFO: CDSPlayer::OnStartup Loading file. Elapsed time: 504.86ms
23:44:35 T:1116 DEBUG: Thread CDSPlayer 1116 terminating
