2011-07-31, 04:40
I've recently ran into a problem using a harmony remote in the new confluence skin. Pushing the menu button on the remote while in the home.xml window when nothing is playing is causing me to lose control of the remote. I checked joystick.Harmony.xml and when pushing the menu button on the remote while in the home.xml window is supposed to activate the PlayerControls.xml which the xbmc.log shows is happening but no window is displayed and I am unable to exit the window, I am able to hear navigation sounds.
I found that if I start a video then exit to the home.xml window while the video is playing in the background pushing the menu button does bring up the PlayerControls.xml window which I can see, navigate and exit.
I'm using a 1stgen AppleTV running Sam Nazarkos crystalbuntu distribution the xbmc build is odk-pvr-42.
xbmc.log
I'm happy to lodge a trac ticket but wanted to check here in the forum first.
xbmc.log
