2011-07-31, 17:12
OK I have been following these instructions:
1. Go to http://code.google.com/p/crystalhd-for-osx/, click download and download and unpack crystalhd-for-osx-1.0.1.zip.
2. Open the terminal, type cd and drag your unpacked crystalhd folder into the terminal, it'll look something like "cd /Users/[users]/Desktop/crystal-hd-for-osx-1.0.1"
3. In the terminal, enter
sudo mv BroadcomCrystalHD.kext /System/Library/Extensions
Enter your password when prompted. OS X might complain that the driver isn't properly installed, just click OK and ignore it.
4. In the terminal, enter the following
sudo chown -R root:wheel /System/Library/Extensions/BroadcomCrystalHD.kext
and then
sudo chmod -R 755 /System/Library/Extensions/BroadcomCrystalHD.kext
5. In the terminal, enter
mv libcrystalhd.dylib /usr/lib/
6. In the terminal, enter
sudo chmod 755 /usr/lib/libcrystalhd.dylib
7. In the terminal, enter
mv bcmFilePlayFw.bin /usr/lib/
8. Now your Broadcom driver should be installed. To load it, enter the following in the terminal
sudo kextload /System/Library/Extensions/BroadcomCrystalHD.kext
9. Now the driver should be loaded. Load up your latest XBMC svn and chose Broadcom Crystal HD as the video renderer.
I get as far as step 7, which I stuck a sudo in front of however the terminal returns an error of no such file or directory.
Can some one help me out on that please?
and then
