Hey guys,
I got it and it works great, the most of the needed settings I use are from the above posted link.
But I want to give you my complete and active config.
1. You need the package "lirc" and its dependencies:
sudo apt-get install lirc
2. Then you have to configure lirc:
sudo dpkg-reconfigure lirc
2.1 choose: "Linux input layer (/dev/input/eventX)"
2.2 on ir transmitter choose: "None"
2.3 on custom event interface choose: "/dev/input/by-id/usb-15c2_ffdc-event-if00"
3. "signal-check"
Now you can check if your htpc receives signals from the remote, type "irw" in your terminal and press some buttons on your remote.
--> the result should be something like this:
000000008001006c 00 KEY_DOWN devinput
0000000080010067 00 KEY_UP devinput
0000000080010193 00 KEY_CHANNELDOWN devinput
0000000080010205 00 KEY_NUMERIC_5 devinput
--> maybe you have to do step 4 before the signals are recognized by "irw"
4. stop lirc and edit your hardware.conf
sudo /etc/init.d/lirc stop
sudo nano etc/lirc/hardware.conf
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="Linux input layer (/dev/input/eventX)"
REMOTE_MODULES="lirc_dev"
REMOTE_DRIVER="devinput"
#REMOTE_DEVICE="/dev/lirc0"
REMOTE_DEVICE="/dev/input/by-id/usb-15c2_ffdc-event-if00"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="/usr/share/lirc/remotes/devinput/lircd.conf.devinput"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
5. edit your lircd.conf
sudo nano /etc/lirc/lircd.conf
#This configuration has been automatically generated via
#the Ubuntu LIRC package maintainer scripts.
#It includes the default configuration for the remote and/or
#transmitter that you have selected during package installation.
#Feel free to add any custom remotes to the configuration
#via additional include directives or below the existing
#Ubuntu include directives from your selected remote and/or
#transmitter.
#Configuration for the Linux input layer (/dev/input/eventX) remote:
include "/usr/share/lirc/remotes/devinput/lircd.conf.devinput"
--> proof the availibility of the lircd.conf.devinput on your system!
6. edit the Lircmap.xml
sudo nano /home/xbmc/.xbmc/userdata/Lircmap.xml
<lircmap>
<remote device="devinput">
<!--KEY_EXIT-->
<power>KEY_POWER</power>
<record>KEY_RECORD</record>
<play>KEY_PLAY</play>
<!--KEY-EJECTCD-->
<reverse>KEY_REWIND</reverse>
<pause>KEY_PAUSE</pause>
<forward>KEY_FASTFORWARD</forward>
<skipminus>KEY_PREVIOUS</skipminus>
<stop>KEY_STOP</stop>
<skipplus>KEY_NEXT</skipplus>
<back>KEY_BACKSPACE</back>
<!--CHOOSE_KBD_MOUSE-->
<select>KEY_SPACE</select>
<!--KEY_COMPOSE-->
<!--BTN_RIGHT-->
<select>KEY_ENTER</select>
<!--BTN_LEFT-->
<menu>KEY_CONTEXT_MENU</menu>
<down>KEY_DOWN</down>
<left>KEY_LEFT</left>
<up>KEY_UP</up>
<right>KEY_RIGHT</right>
<clear>KEY_ESC</clear>
<!--KEY_DASHBOARD-->
<display>KEY_MEDIA</display>
<!--KEY_EJECTCLOSECD=obc2-->
<!--KEY_CYCLEWINDOWS-->
<mute>KEY_MUTE</mute>
<volumeplus>KEY_VOLUMEUP</volumeplus>
<volumeminus>KEY_VOLUMEDOWN</volumeminus>
<channelplus>KEY_CHANNELUP</channelplus>
<channelminus>KEY_CHANNELDOWN</channelminus>
<!--KEY_TIME=obc1-->
<one>KEY_NUMERIC_1</one>
<two>KEY_NUMERIC_2</two>
<three>KEY_NUMERIC_3</three>
<four>KEY_NUMERIC_4</four>
<five>KEY_NUMERIC_5</five>
<six>KEY_NUMERIC_6</six>
<seven>KEY_NUMERIC_7</seven>
<eight>KEY_NUMERIC_8</eight>
<nine>KEY_NUMERIC_9</nine>
<star>KEY_NUMERIC_STAR</star>
<zero>KEY_NUMERIC_0</zero>
<hash>KEY_NUMERIC_POUND</hash>
<myvideo>KEY_VIDEO</myvideo>
<mymusic>KEY_AUDIO</mymusic>
<!--My_Photo_without_function-->
<myTV>KEY_TV</myTV>
<!--KEY_BOOKMARKS-->
<mypictures>KEY_CAMERA</mypictures>
<select>KEY_ZOOM</select>
<title>KEY_SCREEN</title>
<!--KEY_DVD=obc3-->
<menu>KEY_MENU</menu>
<subtitle>KEY_SUBTITLE</subtitle>
<language>KEY_LANGUAGE</language>
<obc1>KEY_TIME</obc1>
<obc2>KEY_EJECTCLOSECD</obc2>
<obc3>KEY_DVD</obc3>
</remote>
</lircmap>
--> set the user-permissions:
sudo chown xbmc:xbmc /home/xbmc/.xbmc/userdata/Lircmap.xml
7. edit your global remote.xml
sudo nano /usr/share/xbmc/system/keymaps/remote.xml
You only have to put the "universalremote"-section to your remote.xml!
<global>
<remote>
<play>Play</play>
<pause>Pause</pause>
<stop>Stop</stop>
</remote>
<universalremote>
<obc1>XBMC.ActivateWindow(Weather)</obc1>
<obc2>EjectTray()</obc2>
<obc3>PlayDVD</obc3>
</universalremote>
</global>
--> start lirc
sudo /etc/init.d/lirc start
Now everything should work, maybe you have to reboot or stop and start xbmc with the following commands:
service xbmc stop
service xbmc start
8. If your remote is to sensitive, build the following config:
sudo nano /home/xbmc/.xbmc/userdata/advancedsettings.xml
#/home/xbmc/.xbmc/userdata/advancedsettings.xml
<advancedsettings>
<remotedelay>5</remotedelay>
<remoterepeat>650</remoterepeat>
</advancedsettings>
sudo chown xbmc:xbmc /home/xbmc/.xbmc/userdata/advancedsettings.xml
Many thanks to lyka, toddwv and krautmaster helped me to get the solution with their "comments" in the above posted link.
Greetings
Hoppel
