Full Version: Movie Posters...
Hey guys, I'm having issues with Movie Posters not displaying.
I made sure that the images are inside the video folder as but for some reason my new movies won't display...
I usually go through Ember Media Manager and get all the artwork for the poster, fanart... And it would easily scrape it and save into the correct folder.
The past 2 months I haven't had one movie that shows up with a poster. Fanarts work fine and it gets added to the library.
The only problem is the posters...
I do clean the library several times, and I've test the image files as .tbn or jpg. And I've even had them saved as:
~ movie.jpg/tbn
~ poster.jpg/tbn
I've got no clue why it's not working...
Any ideas peopleHuh
You'll have to have a peek in your movie folder.... it needs a folder.jpg file to show up as a cover without scanning into your lib. Check out the wiki's http://wiki.xbmc.org/index.php?title=XBM...he_Library
PatK Wrote:You'll have to have a peek in your movie folder.... it needs a folder.jpg file to show up as a cover without scanning into your lib. Check out the wiki's http://wiki.xbmc.org/index.php?title=XBM...he_Library
You're exactly right! Ember Media Manager wasn't adding folder.jpg images inside the movie folders.
I must have unticked it from the software....
Appreciate your help PatK!
I am facing the same issue. However I have a folder.jpg inside every folder. The jpgs are stored in same directly as movbie file. The fanrts are shown correctly.
All my movie posters are named as folder.jpg and all fanarts are named as <moviename>-fanart.jpg
