Full Version: Insert item in library through python/json api
I was wondering if there is any way I can perform a "scan item to library" from python api or from the json api?
On the same topic is there a way I can define a video source as being Tv shows, movies or music videos from python/json api?
My idea is to create a web interface for management of the video/music/image sources of several XBMC machines on the network. I saw that altering the sources.xml file I can add sources, what I don't know is how to manipulate the library.
Thanks in advance,
Nuno
Well I discovered that one can update the music library with the builtin command:
UpdateLibrary(database,[path])
like this:
UpdateLibrary(Music,smb://path-to-media)
I'm not finding a way to do "set content" for movies through the api's.
