Full Version: TV, Video, and Music Homescreen all go to same thing
I'm using the latest SVN of Neon. From the homescreen, my Movies, TV, and Video selections all go to the same thing.
If I was last browsing movies for example, then go to the homescreen, and then select TV Shows, i'll be brought back to movies.
I've tried updating the 'set as default' for each but it doesn't seem to make any difference.
what version of xbmc are you running? Sounds like you are using a skin based on Eden but running Dharma.
Yep, thats the problem... Thanks.
Anyone have a suggestion on the best nightly to try out?
The one fom last night? Smile
