Hi
title says it all, even when running it as root I get segfaults
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Sat Aug 6 23:51:58 EST 2011
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.38-2-amd64 #1 SMP Sun May 8 13:51:57 UTC 2011
Release:
Distributor ID: Debian
Description: Debian GNU/Linux testing (wheezy)
Release: testing
Codename: wheezy
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /root/core (2011-08-06 23:51:58.000000000 +1000)
[New Thread 16454]
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f3418ba3b44 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
Thread 1 (Thread 16454):
#1 0x00007f3418e027c8 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#2 0x00007f3418972d83 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#3 0x00007f3418e0e060 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#4 0x00007f341897eb91 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#5 0x00007f3418b91b10 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#6 0x00007f3418b7274d in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#7 0x00007f3424717561 in ?? () from /usr/lib/x86_64-linux-gnu/libGL.so.1
#8 0x00007f342471bb30 in ?? () from /usr/lib/x86_64-linux-gnu/libGL.so.1
#9 0x00007f3420487d42 in ?? () from /usr/lib/libSDL-1.2.so.0
#10 0x00007f342048bbac in ?? () from /usr/lib/libSDL-1.2.so.0
#11 0x00007f342048bd95 in ?? () from /usr/lib/libSDL-1.2.so.0
#12 0x00007f342047e37e in SDL_VideoQuit () from /usr/lib/libSDL-1.2.so.0
#13 0x00007f3420454d75 in SDL_QuitSubSystem () from /usr/lib/libSDL-1.2.so.0
#14 0x00007f3420454e2e in SDL_Quit () from /usr/lib/libSDL-1.2.so.0
#15 0x00007f34204553df in ?? () from /usr/lib/libSDL-1.2.so.0
#16 <signal handler called>
#17 0x0000000000000000 in ?? ()
#18 0x00007f3418e03fe0 in ?? () from /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.280.13
#19 0x0000000000abcdf9 in CGUITextureGL::End() ()
#20 0x0000000000abc747 in CGUITextureBase::Render() ()
#21 0x0000000000a8d5eb in CGUIImage::Render() ()
#22 0x00000000006c0a86 in CSplash::Show() ()
#23 0x00000000007316ef in CApplication::Create() ()
#24 0x0000000000618685 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
23:51:57 T:139862028126272 M:5883633664 NOTICE: -----------------------------------------------------------------------
23:51:57 T:139862028126272 M:5882609664 NOTICE: Starting XBMC, Platform: Linux (Debian GNU/Linux testing (wheezy), 2.6.38-2-amd64 x86_64). Built on Jun 7 2011 (Git:Unknown)
23:51:57 T:139862028126272 M:5882609664 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:51:57 T:139862028126272 M:5882609664 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
23:51:57 T:139862028126272 M:5882609664 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
23:51:57 T:139862028126272 M:5882609664 NOTICE: special://home/ is mapped to: /root/.xbmc
23:51:57 T:139862028126272 M:5882609664 NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
23:51:57 T:139862028126272 M:5882609664 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
23:51:57 T:139862028126272 M:5882609664 NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
23:51:57 T:139862028126272 M:5882609664 NOTICE: -----------------------------------------------------------------------
23:51:57 T:139862028126272 M:5883125760 NOTICE: Setup SDL
23:51:57 T:139862028126272 M:5882597376 NOTICE: load settings...
23:51:57 T:139862028126272 M:5882597376 ERROR: Unable to load libcrystalhd.so.2, reason: libcrystalhd.so.2: cannot open shared object file: No such file or directory
23:51:57 T:139862028126272 M:5882597376 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:51:57 T:139862028126272 M:5882597376 NOTICE: loading special://masterprofile/guisettings.xml
23:51:57 T:139862028126272 M:5882597376 ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
23:51:57 T:139862028126272 M:5882597376 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
23:51:57 T:139862028126272 M:5882597376 ERROR: DeleteFile - cant delete file </root/.xbmc/userdata/guisettings.xml>. trying lower case </root/.xbmc/userdata/guisettings.xml>
23:51:57 T:139862028126272 M:5882597376 NOTICE: Getting hardware information now...
23:51:57 T:139862028126272 M:5882597376 NOTICE: Checking resolution 12
23:51:57 T:139862028126272 M:5882597376 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:51:57 T:139862028126272 M:5882597376 NOTICE: Loaded playercorefactory configuration
23:51:57 T:139862028126272 M:5882597376 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:51:57 T:139862028126272 M:5882597376 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:51:57 T:139862028126272 M:5882597376 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
23:51:57 T:139862028126272 M:5882597376 NOTICE: Default DVD Player: dvdplayer
23:51:57 T:139862028126272 M:5882597376 NOTICE: Default Video Player: dvdplayer
23:51:57 T:139862028126272 M:5882597376 NOTICE: Default Audio Player: paplayer
23:51:57 T:139862028126272 M:5882597376 NOTICE: Loading media sources from special://masterprofile/sources.xml
23:51:58 T:139862028126272 M:5877047296 NOTICE: Using visual 0x43
23:51:58 T:139862028126272 M:5874851840 NOTICE: GL_VENDOR = NVIDIA Corporation
23:51:58 T:139862028126272 M:5874851840 NOTICE: GL_RENDERER = GeForce 9800 GT/PCI/SSE2
23:51:58 T:139862028126272 M:5874851840 NOTICE: GL_VERSION = 3.3.0 NVIDIA 280.13
23:51:58 T:139862028126272 M:5874851840 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
23:51:58 T:139862028126272 M:5874851840 NOTICE: GL_EXTENSIONS = GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility
GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_texture_type_2_10_10_10_REV GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
23:51:58 T:139862028126272 M:5874851840 ERROR: GLX: Same window as before, refreshing context
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
