2011-08-07, 14:26
When playing movies in XBMC I only get sound from my front (left & right) speakers but no sound from center or rear speakers. The HTPC (upgraded Dell Optiplex GX620) is connected to the TV through HDMI and to my Marantz SR8300 AV-Receiver with use of a optical cable.
I’ve selected below options in XBMC under Settings / System / Audio output:
- Optical / Coaxial
- 5.1
- DTS capable receiver
- Sound Blaster X-Fi Xtreme Audio
Remark: another strange thing is when I select Dolby Digital (AC3) Capable Receiver, I get the following error message: failed to initialize audio device / check your audio settings. This is strange because although my receiver is 7 years old in my understanding it is AC3 capable. See link for specs on the receiver. http://www.marantz.eu/attachments/produc...ual_en.pdf
I know for sure that the AV-Receiver is set up correctly and cabling is done right as well because when I play a movie with PowerDVD I get 5.1 sound. (Use S/PDIF selected in PowerDVD)
As it works in PowerDVD I think it’s got something to do with a Dolby / DTS pass-through error with XBMC as the soundcard is not capable to do decoding XBMC must be told this need to be done by the receiver
Anyway I hope somebody on the forum can help me as I’m already searching the internet for 3 days to find a solution for my problem.
Additional info:
- Sound card = Creative Labs X-Fi Xtreme Audio PCI-E 7.1 PCI-E
- Onboard video and audio is disabled in BIOS
- Optical / Coaxial
- 5.1
Additional info:
