Full Version: Issue with Stream Added to Custom Menu
Hello.
I've created a Custom entry for the Home Menu in Skin Settings; 10 favorites. However, I've an issue with two of the favorites I've entered.*
One, for instance, is an ESPN stream from within SportsDevil. Just straight to the stream, not to the plugin itself, if that makes sense. When I choose this favorite, via the new Menu entry, the stream plays just fine. Though, when I try to exit, it closes the stream then immediately reopens it, giving no time to get back to the main Home Menu. I have to unplug the ATV to get back to normal behavior.*
I'm not at home at the moment and it's just occurred to me that I haven't tried to quit it from just the Favorites menu, to see if it acts similarly.*
Any ideas?
not really...but i'll see if i can reproduce.
please pastebin a Debug Log, it might contain some clues :-)
Thanks ronie.
I was on break from work when I originally posted. As it turns out, it's not a skin issue. Sorry. I'm getting the same results quitting the stream from Confluence. And it's from the Favorites window.
Again, if I open SportsDevil from Favorites and navigate to ESPN, then quit, everything is fine. But creating a Favorites link straight to the ESPN stream, then quitting, reopens the stream and requires me unplugging the box.
I should add, I'm using Crystalbuntu with an ATV1.
I'm reposting this in its proper place.
http://pastebin.com/PiFsXmPG
ronie Wrote:not really...but i'll see if i can reproduce.
