Hello,
I installed nightly build and I've seen that it's possible to play from here in tv show library at episode level via context menu.
I would like to add this fonction on my keyboard.
Can someone can help me ?
Perhaps is there a build in function or a sendclick
thank you
w2w
Hitcher Wrote:p
Some letters are missing?
Ok, so the key p is hardcoded to lauch directly all episodes.
I'm gonna try
It doesn"t work.
do you have another suggestion ?
Hudson_Hawk04 Wrote:http://wiki.xbmc.org/?title=Global_Keyboard
that would be a good place to start looking.
There is nothing I can find in this link.
the key "p" = play
In tv show library, play doesn't "play from here".
xbmc says "can't find a next item"
As p or play doesn't "play from here, I wonder if I can use a built in something like that.
example: audionextlanguage, toggle audio languages.
Or sendclick function (function sendclick(25,14) hide/unhide watched)
w2w
Worked for me. Pressed 'p' on a series and the first episode played, tabbed out and pressed 'space' to check the playlist and it was filled with all the episodes.
Nothing in the playlist, I checked.
I'm talking about the 'play from here' option at episode level. Not the 'play' option at season level that plays entire season from episode 1 to the last.
With play from here option I can play, for example, from episode 10 to the last.
the key 'p' doesn't work in that way
I wonder if the difference between your and Hitcher's experience is due to a difference in the way the series have been scanned to the library ...
JR
Sorry, you didn't say this was at Episodes level.
wolfodeiwolfy Wrote:In tv show library, play doesn't "play from here".
You're right, I'm sorry.
I tried some things in keymap:
sendclick(106,1002) to open context menu (id 106) and launch "play from from here" (choice number 2 in context menu). But it doesn't work at all.
OnPlayandQueueMedia doesn't work too
I don't what to do.
I hope you can help as I give correct clues
w2w
Some ideas about my question?
w2w
