Full Version: Lowlist for new Confluence
I love the new confluence, especially the addons on the home menu. I did some changes to get seven instead of five addon shortcuts, and added another home menu item LiveTV not for Pvr but for all the addons that I have which shows streams.
Now I wish I can get the only thing missing, and that is a lowlist view for Movies, TV Shows (with poster), and Music (album, artist, song view, etc.). I don't like the fanart totally covered, but I don't wnt minimalistic views on fanrt that i get from Transparency. I still want dome plot , duration ect info for the highlighted item.
Any ideas how to get these views? Basically how are extra views added? each in its own xml, but then how is the view added under the options for each type of media? What skin might have a good place to copy it from? Confluence modded by Nate?
Thanks,
Ntiin.
Its not hard to add the lowlist view from the "customizable confluence" mod to the default confluence skin, but it doesnt look right and i have no idea how to fix it
this is what it looks like when you add it to the default confluence skin:
http://i.imgur.com/sbPW7.jpg
and this is what it looks like in customizable confluence:
http://i.imgur.com/XzOKw.jpg
I would love to have lowlist view plus the media info 2 view from customizable confluence added to the default confluence because I prefer everything else about the default confluence skin
That is pretty close I would say. Just a backing black semi transparent backing frame to the text is missing. That should be staright forward to add. Can you tell me how you did this? And also if the same is applicable to TV shows for, show, season as well as episode view. And also music views, for artists, albums, and song views.
Low list does seem like a view which should be there by default. Maybe Jezz_X might added it next time.
