Full Version: Detailed instructions & files needed for Animated Weather Icons
Can anyone please provide detailed instructions and the files needed to enable animated weather icons on the Home screen??
I'm using PM3.HD
Thanks in advance
Can anyone please helpHuh
Thanks in advance
kind of like this http://forum.xbmc.org/showthread.php?tid=107253 as for files no idea search the forum plenty of other skins have them
I followed the guide found here, its also a much nicer skin Smile
http://forum.xbmc.org/showthread.php?tid=89151
"How to enable weather backgrounds based on current conditions:
- Download a map pack and unzip to a folder of choice. (for instance here)
- Go to System-->Skin-->General and enable Weather Backgrounds Based on Current Conditions option.
- Set the path to your map pack.
How to enable animated weather icons:
- Download an icon pack and unzip to a folder of choice. (for instance here)
- Go to System-->Skin-->General and enable Animated Weather Icons option.
- Set the path to your icon pack."
