2011-08-10, 20:48
Hello, seeing the Giada Cube 330/ION on sale for 139$ (http://www.newegg.ca/Product/Product.asp...6856176002), I'm about to buy it. I'd like to buy also a remote to pair it with the Giada from Newegg also. From these choice, is there a remote that you recommend over the other? I it don't need anything fancy, as long as it works!
I plan to use either XBMC Live or Mint KDE 10 with XBMC over it.
http://www.newegg.ca/Product/Product.asp...6880101002
http://www.newegg.ca/Product/Product.asp...6880121002
http://www.newegg.ca/Product/Product.asp...3166095CVF
http://www.newegg.ca/Product/Product.asp...6880111041
Side question : I will buy this RAM, seems ok? http://www.newegg.ca/Product/Product.asp...6820231155
Thank you!
Thank you!
