I can add favorites and they work but when I enter them into the setting custom menu. After clicking on the favorite in the home page menu it goes to a empty page.
Isuris Wrote:I can add favorites and they work but when I enter them into the setting custom menu. After clicking on the favorite in the home page menu it goes to a empty page.
could you pastebin a
Debug Log ?
Isuris Wrote:LOGS
cheers...
there was a bug in xbmc that's causing this.
it was fixed today, so wait for the next nightly build and you should be good to go.
all you need to do then is remove the favourite from the custom button and re-add it again.
thank you
I am very new to svn. Does the nightly build work automatic or is it something i have to do manually?
Isuris Wrote:thank you
i'm talkin about
xbmc nightly builds and since you're running one,
you should know what to do :-)
I think I got it,hahahha.
Thanks for the help
I am still not getting folders that I pick as favorites.But, single files work great.I am running this night build XBMCSetup-20110822-2722c9e-master.exe.
kevin
Isuris Wrote:I am still not getting folders that I pick as favorites.But, single files work great.I am running this night build XBMCSetup-20110822-2722c9e-master.exe.
kevin
Debug Log ?
He's looking for a debug log. You need to go into user settings>system>debug>enable debugging. Exit XBMC, restart.
looks like a bug to me:
Quote:15:31:53 T:4716 WARNING: CUtil::SplitParams(10025,"E:\Documentary\",return) - end of string while searching for ) or "
thought we had that one fixed...
doesn't happen on my end (linux), so might be a windows problem only.
i'll ask around.
