2011-08-11, 17:20
Hello, all. When the AMD Llano was announced -- the A8-3850 in particular -- I was pretty excited. It seemed like the perfect processor for a budget (under $500) HTPC setup, and you didn't even have to spend money on a dedicated GPU.
After reading this review however, I'm beginning to wonder if I should go the i3 route instead... then again, the back-and-forth in the comments section of that same article confused me even more.
If I go for the Llano will I have any problems with the following? This is what I want to do with my HTPC: play BluRays (at full 1080@24p), my own movies (1080@60p), play Netflix, Hulu, etc. and play high quality FLACS. I want the quality to be really good, too.
Am I better off going with an i3 + dedicated GPU? If so, what particular components would you all recommend?
Thanks in advance.
Thanks in advance.
