Full Version: Scrappers suddenly stopped working
Hi all,
Im using Windows 7 x64 XBMC 10.1.
Today I was adding some new media and everything was working fine, about 1 hour later I added one more file and tried to scan for new content without success.
I tested with a tv show trying to refresh the all information and I received an error stating it couldnt contact remote server. Movie's are doing the same.
Below is the debugging logs from the refresh of a tv show and also scanning for new content for a tv show.
Any help would be greatly appreciated.
00:27:05 T:1452 M:2288766976 DEBUG: CApplication::OnKey: 61453 pressed, action is Select
00:27:05 T:1452 M:2288746496 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
00:27:05 T:1452 M:2288746496 DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
00:27:05 T:1452 M:2328236032 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'E:\TV\The Vanilla Ice Project\'
00:27:05 T:1452 M:2328236032 INFO: Loading skin file: DialogProgress.xml
00:27:05 T:1452 M:2328231936 DEBUG: ------ Window Init (DialogProgress.xml) ------
00:27:06 T:1452 M:2320658432 DEBUG: Win32DllLoader::Load(special://xbmcbin/system/libcurl.dll)
00:27:06 T:1452 M:2320408576 DEBUG: Win32DllLoader::Load(special://xbmcbin/system/libidn-11.dll)
00:27:06 T:1452 M:2320408576 DEBUG: Win32DllLoader::Load(special://xbmcbin/system/libeay32.dll)
00:27:06 T:1452 M:2320408576 DEBUG: Win32DllLoader::Load(special://xbmcbin/system/libssl32.dll)
00:27:06 T:1452 M:2320031744 DEBUG: Win32DllLoader::Load(ADVAPI32.DLL)
00:27:06 T:1452 M:2320031744 DEBUG: Win32DllLoader::Load(KERNEL32.DLL)
00:27:06 T:1452 M:2320031744 DEBUG: Win32DllLoader::Load(NETAPI32.DLL)
00:27:06 T:1452 M:2319855616 DEBUG: FreeLibrary(NETAPI32.DLL) -> 0E995308
00:27:06 T:1452 M:2319855616 DEBUG: Win32DllLoader::Unload NETAPI32.DLL
00:27:06 T:1452 M:2319994880 DEBUG: FreeLibrary(ADVAPI32.DLL) -> 0E991438
00:27:06 T:1452 M:2319994880 DEBUG: Win32DllLoader::Unload ADVAPI32.DLL
00:27:06 T:1452 M:2319994880 DEBUG: Win32DllLoader::Load(USER32.DLL)
00:27:06 T:1452 M:2319994880 DEBUG: FreeLibrary(USER32.DLL) -> 0E991438
00:27:06 T:1452 M:2319994880 DEBUG: Win32DllLoader::Unload USER32.DLL
00:27:10 T:1152 M:2319069184 DEBUG: Thread 1152 terminating
00:27:12 T:1452 M:2319212544 DEBUG: FreeLibrary(KERNEL32.DLL) -> 0E9838D8
00:27:12 T:1452 M:2319278080 DEBUG: Win32DllLoader::Unload KERNEL32.DLL
00:27:12 T:1452 M:2319265792 DEBUG: Win32DllLoader::Load(secur32.dll)
00:27:12 T:1452 M:2319204352 DEBUG: SDLKeyboard: scancode: 72, sym: 273, unicode: 0, modifier: 0
00:27:12 T:2024 M:2319204352 DEBUG: thread start, auto delete: 0
00:27:12 T:1452 M:2319204352 DEBUG: CApplication::OnKey: 61478 pressed, action is Up
00:27:12 T:2024 M:2319200256 DEBUG: CIMDB::InternalFindMovie: Searching for 'the vanilla ice project' using The TVDB scraper (path: 'C:\Users\rodney\AppData\Roaming\XBMC\addons\metadata.tvdb.com', content: 'tvshows', version: '1.2.3')
00:27:12 T:2024 M:2319200256 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=the%20vanilla%20ice%20project&amp;language=en</url>
00:27:12 T:2024 M:2319200256 DEBUG: FileCurl::Open(0018DA08) http://www.thetvdb.com/api/GetSeries.php...anguage=en
00:27:12 T:2024 M:2319175680 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://www.thetvdb.com
00:27:22 T:2024 M:2319101952 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
00:27:22 T:2024 M:2319101952 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
00:27:22 T:2024 M:2319101952 DEBUG: FileCurl::Close(0018DA08) http://www.thetvdb.com/api/GetSeries.php...anguage=en
00:27:22 T:2024 M:2319101952 ERROR: ADDON::CScraper::Run: Unable to parse web site
00:27:22 T:2024 M:2319101952 ERROR: CIMDB:Tonguerocess: Error looking up item The Vanilla Ice Project
00:27:22 T:2024 M:2319101952 DEBUG: Thread 2024 terminating
_________________________________________________________________________
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e01.720p.hdtv.x264-dimension.mkv (s5e1) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e02.720p.hdtv.x264-ctu.mkv (s5e2) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e03.720p.web-dl.dd5.1.h264-kings.mkv (s5e3) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e04.720p.web-dl.dd5.1.h264-kings.mkv (s5e4) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e05.720p.hdtv.x264-dimension.mkv (s5e5) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e06.720p.web-dl.dd5.1.h.264-kings.mkv (s5e6) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e07.720p.hdtv.x264-dimension.mkv (s5e7) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320564224 DEBUG: VideoInfoScanner: Found episode match e:\tv\burn notice\season 5\burn.notice.s05e08.720p.hdtv.x264-dimension.mkv (s5e8) [[Ss]([0-9]+)[][._-]*[Ee]([0-9]+)([^\\/]*)$]
00:27:33 T:3052 M:2320052224 DEBUG: FileCurl::Open(0544F12C) http://www.thetvdb.com/api/1D62F2F90030C...all/en.zip
00:27:43 T:3052 M:2290421760 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
00:27:43 T:3052 M:2290405376 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
00:27:43 T:3052 M:2290405376 DEBUG: FileCurl::Close(0544F12C) http://www.thetvdb.com/api/1D62F2F90030C...all/en.zip
00:27:43 T:3052 M:2290405376 ERROR: ADDON::CScraper::Run: Unable to parse web site
00:27:44 T:3052 M:2330439680 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E01.720p.HDTV.X264-DIMENSION.mkv), query = select idEpisode from episode where idFile=14730
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\burn.notice.s05e02.720p.hdtv.x264-ctu.mkv), query = select idEpisode from episode where idFile=14731
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E03.720p.WEB-DL.DD5.1.H264-KiNGS.mkv), query = select idEpisode from episode where idFile=15216
00:27:44 T:3052 M:2330509312 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E04.720p.WEB-DL.DD5.1.H264-KiNGS.mkv), query = select idEpisode from episode where idFile=20601
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E05.720p.HDTV.X264-DIMENSION.mkv), query = select idEpisode from episode where idFile=16114
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E06.720p.WEB-DL.DD5.1.H.264-KiNGS.mkv), query = select idEpisode from episode where idFile=20602
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E07.720p.HDTV.X264-DIMENSION.mkv), query = select idEpisode from episode where idFile=20693
00:27:44 T:3052 M:2330513408 DEBUG: CVideoDatabase::GetEpisodeId (E:\TV\Burn Notice\Season 5\Burn.Notice.S05E08.720p.HDTV.X264-DIMENSION.mkv), query = select idEpisode from episode where idFile=20982
00:27:44 T:3052 M:2330513408 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'E:\TV\Burn Notice\Season 5\Burn.Notice.S05E08.720p.HDTV.X264-DIMENSION.mkv'
00:27:44 T:3052 M:2330513408 ERROR: VideoInfoScanner: Asked to lookup episode E:\TV\Burn Notice\Season 5\Burn.Notice.S05E08.720p.HDTV.X264-DIMENSION.mkv online, but we have no episode guide. Check your tvshow.nfo and make sure the <episodeguide> tag is in place.
I could have been that the database was down temporarily. Try again later... and if you want people to look at your debug, past-it at pastebin.com and post the link.... instead of filling up with forums with unneeded data.
PatK Wrote:I could have been that the database was down temporarily. Try again later... and if you want people to look at your debug, past-it at pastebin.com and post the link.... instead of filling up with forums with unneeded data.
TVDB is definitely down right now (as of 1pm EST). It appears there is one guy in the entire world who manages the backend servers, and we have to wait until he gets time to look at the issue. The good news is the theTVDB folks seem to have one moderator dedicated to making snarky and sarcastic remarks about other users posts. He is continuing along without any apparent interruption right now. Wink
That retard still a mod there? It's amazing anything gets done on there with idiots like that.
