2011-08-13, 03:10
i am putting together a home server to store all my movies and shows on which will then stream to my htpc with xbmc
i am think of buying the western digital 2tb green drives (probably eventually about 8 of them)
the models available to me are
Western Digital Green 2TB WD20EARX
Western Digital Green 2TB WD20EADS
are these good reliable drives as although i will have offline backups i want to know my data is safe on them
i do NOT plan to have them in a raid array as i personally don't trust raid as one card dies or a software error can cost me all my data if i simply have each drive independant and keep offline backups on a secondary drive if any of those drives goes i only lose what's on there instead of all of it the difference between 2tb and 16tb
i do have a raid card installed but using it as a non-raid option just so i can get an extra 4 hard drives installed as my onboard only has 6 sata ports and one is being taken by a 2.5 toshiba laptop drive as the boot drive running windows 7 x64 ultimate
also apart from if these drives are good i also want to know i have a 620watt seasonic S2II PSU installed would this be enough power for 8 or 9 drives total plus obviously running the motherboard
