Full Version: Need banners and posters
Hi all. I just had to reinstall xbmc live due to a file system corruption. I am using transparency which prefers banner.jpg for tv shows for the most part. Most of my shows already have posters saved as folder.jpg in their respective folders. Through some searching I have found that the latest logo downloader script has the capability of downloading a banner.jpg, clear art, logo, etc. As long as you edit some Custom_SkinSetting_1111.xml or something like that (I think) is this is the right file to edit? If so, where is it? If not, what do I edit? Thanks guys.
misterbeauds Wrote:Hi all. I just had to reinstall xbmc live due to a file system corruption. I am using transparency which prefers banner.jpg for tv shows for the most part.
hmm, i'm pretty sure T! doesn't use banner.jpg at all.
you can set the skin to use banners or posters in skin settings.
filename should be folder.jpg in both cases.
thanks for responding Ronie.
